I made the following updates in June 2020:
- Replaced LED with Bivar MPC5ADW6.0 and 820 ohm (I think) resistor
- Replaced power entry jack with Schurter 5120.0303.0 PEM filter
- Removed volume control
- Moved bias select switch from back to front (where volume control used to be)
- Replaced signal wire with Mogami W2330
