I made the following updates in Summer 2018:
- I removed the large bias pots and implemented Dave Gillespie's Enhanced Feedback Bias (EFB). The schematic for the project has been updated to reflect this.
- As a part of this effort, I made an outlet box with a transformer inside that reduces the wall voltage by ~7 VAC in order to bring down the heater and B+ voltages to reasonable levels.
I made the following updates in Summer 2020:
- Replaced LED with Bivar MPC5ADW6.0 and 820 ohm (I think) resistor
- Replaced power entry jack with Schurter 5120.0303.0 PEM filter
- Removed volume control
- Moved bias select switch from back to front (where volume control used to be)
- Replaced signal wire with Mogami W2330
