Axis 6,5 and 4 almost done with bolts and bearings to be added. Going to use a flange that is attached to the nema 8 stepper for adding tools to the end of the arm. Also added cooling holes for axis 5 and 6 as they are more inside the arm compared to others.
steppers inside arm
Motor ventilation and belt provisions.
jasper cusiel
