AVR ISP POGO PIN ADAPTER
Design and build a hand-held AVR-ISP adapter using Pogo pins
Public Chat
Starting from
has orders / reviews
Ships from
It's a 6-pin avr-isp adapter based on Pogo pins that allows you on-board programming without wiring and soldering.
I tried to design a comfort hand-held device.There's a power on led and reset button on it that is covered with an anti-static plastic.
You can use it directly as a 6 pin programming adapter ( 2x3 pins - 2.54 pitch ) or with 10-Pin to 6-Pin converter board compatible with most AVR programmers.
Package include:
1x AVR-ISP adapter1x 10-Pin to 6-Pin converter board
Dimensions:
Pogo Adapter : 100*15*8 mm
IDC converter : 30*20*8 mm
D. E. wrote 11/21/2020 at 20:44 • point
Nice tool but it is better to use a pushbutton with grounded metal shield. That avoids ESD problems when touching the button housing.
Ben Mo wrote 12/24/2020 at 13:15 • point
Thanks dear @D. E.
You're right. i'll consider it for next design.
