I do not know what chip "ET7" and "MH 23 22" are, but they are obviously some kind of buck regulator. A/B/C/D are the GPIO control signals from the MCU (output only).
E6 enables the 3.3v rail, and supplies the 1.8v regulator. IOC/D are powered even if this rail is not.
E4 enables the 1.8v rail to the display connector, but only if E6 is also enabled (for 3.3v). IOA/B are pulled-up to 1.8v if this is enabled.
The 5V rail is always powered.
I am not sure what the deal is with the chip at the top that is fed directly from +5v.
TFT Backlight Driver
For TFTs, there is a dedicated backlight driver:
E9 is obviously an analog feedback signal to the MCU for controlling the drive current, E5 is the main supply enable, and E8 is probably a PWM control signal for defining the drive current.
OLED Bias Voltage
E7 enables the bias circuit.
E10 is probably a PWM drive signal for controlling display brightness.
On my board, the following signals come up in this order when it is powered on:B: Fast Flashing Blue LED
C: Green LED
You can see that on my board, the LED backlight & OLED bias supplies are never turned on. Instead the dsplay board has it's own regulators which are controlled by the IOA/B/C/D GPIOs.
Full connector pinout:
Number | Net Name | Voltage | Breakout Net | Use | Description |
1 | FB1 | | | | Feedback 1 |
2 | FB1 | | | | Feedback 1 |
3 | - | | | | |
4 | - | | | | |
5 | FB2 | | | | Feedback 2 |
6 | FB2 | | | | Feedback 2 |
7 | - | | | | |
8 | V3 | | | | Backlight |
9 | V3 | | | | Backlight |
10 | V3 | | | | Backlight |
11 | - | | | | |
12 | GND | | | | |
13 | V1 | | | | OLED Bias (E7+E10 Ctrl) |
14 | V2 | | | | OLED Bias (E7+E10 Ctrl) |
15 | - | | | | |
16 | - | | | | |
17 | - | | | | |
18 | - | | | | |
19 | IOA | 1.8 | G | Right OLED Enable? | E4 Ctrl |
20 | IOB | 1.8 | F | Right OLED Enable? | E4 Ctrl or Always powered? |
21 | - | | | | |
22 | V_1.8 | 1.8 | E | 1.8v Supply | E4 Ctrl |
23 | - | | | | |
24 | V_3.3 | 3.3 | N | 3.3v Supply (1st) | E6 Ctrl |
25 | V_3.3 | 3.3 | N | 3.3v Supply (1st) | E6 Ctrl |
26 | V_5.0 | 5.0 | | | USB VIN, Always powered |
27 | IOC | 3.3 | L | Enable OLED Bias (2nd) | Always powered |
28 | IOD | 3.3 | M | Enable 2.8v Supply (1st) | Always powered |
29 | - | | | | |
30 | GND | | | | |
31 | DSI0_D0 | | D | | |
32 | DSI0_D0 | | D | | |
33 | GND | | | | |
34 | DSI0_D1 | | | | |
35 | DSI0_D1 | | | | |
36 | GND | | | | |
37 | DSI0_C | | C | | |
38 | DSI0_C | | C | | |
39 | GND | | | | |
40 | DSI0_D2 | | | | |
41 | DSI0_D2 | | | | |
42 | GND | | | | |
43 | DSI0_D3 | | | | |
44 | DSI0_D3 | | | | |
45 | GND | | | | |
46 | DSI1_D0 | | B | | |
47 | DSI1_D0 | | B | | |
48 | GND | | | | |
49 | DSI1_D1 | | | | |
50 | DSI1_D1 | | | | |
51 | GND | | | | |
52 | DSI1_C | | A | | |
53 | DSI1_C | | A | | |
54 | GND | | | | |
55 | DSI1_D2 | | | | |
56 | DSI1_D2 | | | | |
57 | GND | | | | |
58 | DSI1_D3 | | | | |
59 | DSI1_D3 | | | | |
60 | GND | | | | |
