I have attached sketches of prototype 1 (a mini hive), the beehive is intended to be assembled modularly (currently manufactured out of PLA as it is non-toxic, biodegradable and doesn't shrink as much as ABS).
Each part will be attached using bayonet fittings (i have also attached images of how this works) although I still need to determine tolerances. Once tolerances and wall thickness have been determined I will consider how the final design can be scaled up.
![](https://cdn.hackaday.io/images/8339411585237708458.jpg)
![](https://cdn.hackaday.io/images/9183251585237717958.jpg)
![](https://cdn.hackaday.io/images/7103401585237757084.png)
![](https://cdn.hackaday.io/images/8878131585237762529.png)
![](https://cdn.hackaday.io/images/8322581585237761609.png)
Second iteration of this prototype coming soon; with ventilation and insulation improvements.
