Success! I think.
A project log for Cheap-O-NAS
A low-cost solid-state NAS with power-loss protection
robgRobG 11/15/2019 at 16:020 Comments
After a couple more attempts I think I've got the fail-over power supply working, using the dc-dc switcher module. I had to modify the module in two ways:
- bring out the ENable line so I can control it
- remove the trimmer pot and replace with fixed value resistors to give ~5.5V out
- remove the 0.1uF cap on pin 8 so that the 'soft-start' feature is disabled. Without this the switcher takes ~15ms to come up, leaving a nasty gap as it takes over from the mains supply.
Had a play with possibly swapping out the main Schottky for a MOSFET, but it's tricky without resorting to a complete 'ideal diode' circuit (three transistors, two resistors). If it bugs me I might just buy an ideal diode module.
Rich text editor
