Yeah, I decided to give the tiny keyboard thingy one more try, this time with solder paste and hot air gun. Turns out those small buttons have a pretty narrow thermal curve — they get crispy really easily.
Also, weren't they supposed to just magically pop right into their places, instead of clustering together into a single mega-button?
Same thing happened to me when I tried desoldering such a button from the D1 mini PewPew shield using hot air. Soldering them in the oven at ~220 °C peak on the PicoPew worked well though.
Wait, you can solder things at 220°C? I thought solder melts at ~250°C or more if it's lead free...
The Sn63/Pb37 solder paste I used is labeled “183°C” (https://www.banggood.com/XG-Z40-10cc-Syringe-Solder-Paste-Flux-Paste-Sn63Pb37-25-45um-p-973158.html) and the oven controller heats to 218° and then overshoots a little (https://www.rocketscream.com/blog/docs-item/tiny-reflow-controller/).
you are right, I wonder why my soldering iron is set to 400°C...
"Also, weren't they supposed to just magically pop right into their places, instead of clustering together into a single mega-button?" This really depends on the amount and type of solder paste (and pad size) AND hot air flow rate.
I suggest putting a piece of steel or alu on your stove and use that, really reliable!
Edit: I just saw that @davedarko had the exact same idea just before me :)
this might work better on some sort of hotplate? Maybe JLCPCB has more luck with a pcba run?
