- Arduino Beetle (AtMega32u4) with 3 analogue pins
- ground down potentiometer tracks to 0.2mm
- 2mm rails, overall height is 5mm
- carbon resistor tracks can't be soldered, had to mechanically fasten them with M1 screws. If someone knows a PCB service that will make 0.2mm PCBs with printed carbon resistors, let me know.
- the tracks are very heat sensitive with weird failure state (partially working)
- make one hole of the wiper carriage square and oversized, as done on commercially faders with linear rails, to make them more tolerant against misalignment of the rails.
- soldering enameled copper wire is a pain, I butchered the prototype until I discovered headphone cables
- made an USB cable from 4 core headphone cable (1.5mm) too, nice for such a light device.
- first layer typo is generated and exported as gcode via Sverchok, a Blender addon for parametric design
- arduino sketch has a multi-map function that allows you to remap the analogue readout in a non-linear way, to recalibrate 'linear' potentiometers or even convert logscale potentiometers to linear.
The case you've made here almost qualifies as art for perfect under-extrusion at the surface. I like this a lot for several reasons.
