I have an old Psion II LZ handheld and a crazy idea to use this as a remote to control my home automation.
This involves creating an bluetooth adapter for the Psion and connecting via bluetooth to a RPI running the home automation software.
Once, I had the CommLink software installed, the next step was to build the hardware. For this, I again turned to Jaap's site and the schematics drawn by Olivier Gossuin.
(I'm not sure that the schematics are 100% accurate, but they where enough to help me build my own Comms Link)
Since I had the software in a DataPak in slot C, I wasn't sure if it would work with the hardware in the top slot. Only one way to find out - build it and see.
So I built a simple interface using just 2 ICs; a 74HC244 and a 74LS00 (I didnt have a 4011 to hand). I only connected RX and TX (no handshaking signals) and connected them to a USB to serial converter.
It worked! I could communicate between my PC and the Psion at 9600 baud over serial.
I bought the Psion and a number of blank 32K DataPaks. I have no Comms Link so no means to get any data onto the Psion (other than typing it in).
So, the first task was to build a DataPak reader/writer.
Jaap's excellent website https://www.jaapsch.net/psion/ has all the information I needed to build a DataPak reader/writer. Using an adruino pro micro. This uses 8 pins as a data bus, 5 pins for control (RESET, CLOCK, OUTPUT ENABLE, SLOT SELECT and PROGRAM) and one to generate the programming voltage via a boost converter.
With this, I was able to program the CommsLink 4.2 software into a blank DataPak.
Matt this is really nice work.. An Organiser II Forum member 'MartinP' posted a link to this project from his PSION 2 Datapak / RamPack Read/Writer Hackaday project. Have you ever considered joining this Organiser II Forum? It is a very small group and someone with your undoubted skills could add so much to the group. Also even if you don't want to join a forum, you may be aware that Olivier Gossuin's Shop and Wed-Site have now closed and getting hold of his exciting projects and documentation is impossible. So my plea to you is; if you have copies of any of Olivier's documentation could you please copy it to me and I'll make sure they are available to others like yourself who are trying to do these remarkable things with the Organiser. I will not post my email address here but you will find my details by searching Martin Reid PSION.
Also I know a forum member Nickos will be very interested in what you have achieved here as he and Olivier were trying to develop a bluetooth link to connect his surveying equipment to his Organiser II but obviously that work has now stalled.
Sincerely and in good faith
Martin Reid
