Hackaday.io Hackaday.io
Sign up Log in
3D Printed FM Radio using Arduino
FM Radio using RDA5807 FM Radio Tuner IC and Arduino
neeraj-raneNeeraj Rane
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
435 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
477
0
435
10
Team (3)
  • neeraj-raneNeeraj Rane
  • andy-butlerAndy Butler
  • aminimoji0amini.moji0
Join this project's team
hardware
completed project
fm radio arduino RDA5807 3D printed audio MUSIC
This project was created on 11/12/2019 and last updated 6 months ago.
Description
Recently, I came across the RDA5807 module which is an FM Radio Tuner in a very tiny package. It is very cheap and uses the I2C protocol for communication which means that only two wires will be required to talk to the IC. Less wiring!
My mom used to listen to the radio every day while cooking food before the radio died. I wanted to surprise her with a radio which I built myself. To make it look good, I designed an enclosure and 3D printed it. I'm new to 3D designing so it is a simple design. No fancy stuff.
Details
Log In/Sign up to comment
Sign up with Github
OR
Official Hackaday Prize Entry
Hacking a cheap R/C car so it can be controlled using hand gestures.
Project Owner Contributor
Hand Gesture/Movement Controlled R/C Car
ngerenngeren
Studio Grip system using Golf Balls, all thread and 3d printed parts.
Golf Ball Grip. Studio and Lighting Gear System
jesse-schochJesse Schoch
A Fully 3D Printed Arduino Robot Arm for STEM Education
LittleArm 2C: 3D Printed Robot Arm
slantconceptsslantconcepts
3D printed, animatronic, radio controlled corpse for Halloween.
Animatronic Radio Controlled Corpse
nickroosennickroosen
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "3D Printed FM Radio using Arduino", please tell us the reason.
Send message
Remove Member
