Figured out what components I wanted for this board. Only 16 components needed (excluding the Feather!). The BOM can be found on Octopart. This may change if I find I need additional parts.
A project log for u-blox SAM-M8Q GPS Featherwing
A GPS Featherwing for the Adafruit Feather, using a GPS module from u-blox. No external antenna required!
