Test 001 - 10A No Water Cooling
- Had to set current pot at start so first few seconds values are unreliable
- load set to 10A
- No water cooling
- Cells insulated with tea towel to simulate being in centre of pack
- Glue on tape securing cell temp sensors softened towards the end. Sensors could move away from cells. This may have been giving unreliable readings
- Cut off at 2.5V per cell, 80°C on busbar and cells
- Test ended due to low voltage
![](https://cdn.hackaday.io/images/8395131573770390730.png)
Test 002 - 10A No Water Cooling
- load set to 10A
- no water cooling
- cells insulated with tea towel to simulate being in centre of pack. Wrapped more tightly since test 001
- sensors now firmly fixed to cells
- cut off at 2.75V per cell, 80°C on busbar and cells
Test 003 - 10A With Water Cooling
- load set to 10A
- water cooling on, 0.5l water start temp 26°C finish 28°C.
- ended due to low voltage
- Cell temperature significantly reduced from earlier tests with no cooling.
![](https://cdn.hackaday.io/images/762441573770519336.png)
Test 004 - 10A With Water Cooling
- load set to 10A
- water cooling on, 0.5l water start temp 26°C finish 29°C.
![](https://cdn.hackaday.io/images/7932921573770630760.png)
Test 005 - 20A With Water Cooling
- load set to 20A. (was set to 10 at start of test, had to set pot, hence gradual fall in voltage at start of test)
- water cooling on, 0.5l water start temp 25.5°C finish 28.2°C.
![](https://cdn.hackaday.io/images/6366441573770699756.png)
Test 006 - 20A With Water Cooling
- load set to 20A
- sensors now re positioned into wooden frame and replaced with bead sensors (smt thermistors easily damaged)
- Something has happened to dummy load or data logger. Spurious voltage reading.
![](https://cdn.hackaday.io/images/8755161573770756506.png)
Test 007 - 20A With Water Cooling
- load set to 20A
- water cooling on, 0.5l water start temp 25.0°C finish 29.0°C.
- sensors now repositioned into wooden frame and replaced with bead sensors to allow space for more cooling tube coils 12 rows of cooling coils (previously 7)
- checked connections from previous test but voltage reading still suspect.
![](https://cdn.hackaday.io/images/2550271573770857051.png)
Results
The method of cell cooling using wraps of pneumatic hose clearly has some useful effect. During 10A testing the peak temperature was 60°C without cooling, 42°C with cooling.
During the 20A testing the temperature peaked at 62°C with cooling and 7 180° wraps per cell. Increasing wraps to 12 reduced temperatures to 56°C.
I have yet to test a 20A discharge with water cooling disabled. May have to keep a fire extinguisher handy. Will update soon.
Other thermal coupling methods are to be tried also
