Here's a question for all of you folks following this project:
How much of an improvement would it be to convert all of the resistors to SMD (instead of TFT)? It would save a good bit of space, but I'm not sure what I'd be trading off for that.
(I'm re-learning electronics after some 40 years away, so bear with me here! I'm not sure there even were SMD components back then!)
Yeah... this one's calling for 9 resistors, so quite a bit would be opened up, and I might even be able to simplify the layout. Maybe I'll build it as an[other] alternate version, put it up as the main one for the contest, and decide later which way I want to go.
I do know that I have two complete projects in mind (different applications of the voice changer option) that would call for this board.
Thank you for the feedback!
