Features
- Custom 3D printed shell
- Custom linux distribution for fast boot ([from button press to emulationstation in 10 seconds](https://imgur.com/a/TFRGUFs))
- Single press power on and long press power off
- Battery Monitor icon and safe shutdown
- Stereo Speakers, Audio Jack and Volume Control
- 12 Buttons
- 5 inch display
- Raspberry Pi Zero powered
The Pi Zero and the 5 inch display are the reason for the naming *Z5*.
3D Model
The model was designed in Fusion360. If you want to change the design, you can find the whole model here. The STLs are in the Files section and the Github repository. Furthermore there are exported STEP and Fusion360 Archive Files ready to download.
Gerrit
droxpopuli
tlnvwmz
Franklinstein
Wow, you fit a lot inside that case. Bracket system looks great!
