The possibilities of the Raspberry Pis invite you to make the panel a bit smarter. I still have quite a few WS2812b LEDs available, as well as a BOSCH BMP280 sensor with which I can still realize a temperature measurement.
So having all the components together I cut out the cut-out for the display with a jig saw. After this I started designing all the needed parts with fusion 360 and printed them.
Benjamin Prescher
