Parameters that can be user adjusted:
Individual Button sizes
Button Fillets (roundness)
Port to cable tolerance
Case thickness
TODO:Power switch
Split case
Cut out SAO connectors
Allow cutouts to be optional via parameters. Is this possible? A quick search tells me it *might* be but inconclusive.
Cartridge.
Light Pipes/LEDs.
Also see https://hackaday.io/project/168478-hackaday-superconference-2019-badge-enclosure by Tim Trzepacz who I spoke with a few times over the weekend about his badge case regarding things like attaching PCB to case, attaching the enclosure halves, and power switch/button opera
Cool, need to print up an enclosure for my badge. Thanks!
