I Just uploaded a minor update,: v2.1, this has a network watchdog and re-try mechanism so that the unit will now reconnect after a WiFi hiccup, instead of just disconnecting until rebooted. Otherwise it is identical to 2.0.
A project log for $7 ESP32 CAM example expanded
A proper implementation of a ESP32 CAM webserver; based on the Espressif example, but extended for real-world use
