Hackaday.io Hackaday.io
Sign up Log in
Temp Color Lanyard
Lanyard that drives RGB LED to the color of the ambient temperature using an analog temperature measurement
schwarzrmsuschwarzrmsu
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
0 followers
  • Description
  • Details
  • Files 6
    • View all
  • Components 1
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
229
0
0
1
Team (1)
  • schwarzrmsuschwarzrmsu
Join this project's team
hardware
ongoing project
temperature rgb
This project was created on 11/21/2019 and last updated 6 years ago.
Description
This widget will calculate a temperature reading using a thermistor. This temperature will be used to determing the duty cycles of red, green and blue LED's in a single RGB LED. The software will mix red, green and blue in order to show the color of the ambient temperature. 0F is pure blue, 50F is pure green & 100F is pure red. All temperatures will be mixtures of either red/green or blue/green.
Files
TEMP_COLOR_LANYARD_PROTO_2_190325.zip
Software
x-zip-compressed - 353.84 kB - 11/21/2019 at 00:35
Download
TEMP_COLOR_LANYARD_TOP_PROTO_2_190311.step
Top Housing 3D Model
step - 101.14 kB - 11/21/2019 at 00:35
Download
TEMP_COLOR_LANYARD_BOT_PROTO_2_190311.step
Bottom Housing 3D Model
step - 99.58 kB - 11/21/2019 at 00:34
Download
TEMP_COLOR_LANYARD_PROTO_2_190303.zip
PCB Gerber Files
x-zip-compressed - 49.21 kB - 11/21/2019 at 00:34
Download
TEMP_COLOR_LANYARD_PROTO_2_190303.pdf
Schematic
Adobe Portable Document Format - 45.42 kB - 11/21/2019 at 00:34
Preview
View all 6 files
Components
  • 1 × See Attached BOM See Attached BOM
Project Logs
Collapse
  • Temp Color Lanyard Proto 2 Release
    schwarzrmsu • 11/21/2019 at 00:38 • 0 comments
    Uploaded Temp Color Lanyard Proto 2 files and updated all relevant material to reflect this latest revision.
View project log
Log In/Sign up to comment
Sign up with Github
OR
Project Owner Contributor
Human Body Infrared Smoke Temperature Alarm System
icstationicstation
Costie is a smart LED table top coaster that reacts to changes in temperatures of objects kept on it.
Costie
akshay-bawejaAkshay Baweja
A light that displays the temperature outside as color
OrbLight
petereiterpete.reiter
Thermistors are the very basic electronics component used in variety of circuits for temperature monitoring, safety purposes and as fuses.
NTC v/s PTC main difference and applications
sagar-001Sagar 001
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Temp Color Lanyard", please tell us the reason.
Send message
Remove Member
