Hackaday.io Hackaday.io
Sign up Log in
Interactive Electronic Birthday Card
Interactive electronic birthday card where you can blow out the candles and the card will sing you happy birthday
schwarzrmsuschwarzrmsu
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
4 comments
3 followers
  • Description
  • Details
  • Files 4
    • View all
  • Components 1
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 4
View Gallery
936
4
3
4
Team (1)
  • schwarzrmsuschwarzrmsu
Join this project's team
hardware
ongoing project
birthday card
This project was created on 11/21/2019 and last updated 7 years ago.
Description
This interactive electronic birthday card allows the recipient to interact with the card in a unique way. The card appears to have flickering candles on top of a birthday cake by using individually PWMed LED's. Using microphones, I have characterized the noise signature of someone blowing out the candles. When this signature is recognized, the LED's will start to go out depending on their location to the microphone. This gives the user the sensation of blowing out the candles. Once all of the candles have been blown out, the card will sing you happy birthday by using a piezo-electric buzzer.
Files
BIRTHDAY_CARD_181208.zip
Software
x-zip-compressed - 3.13 kB - 11/21/2019 at 01:12
Download
BIRTHDAY_CARD_PROTO_2_181126.zip
PCB Gerbers
x-zip-compressed - 92.38 kB - 11/21/2019 at 01:11
Download
BIRTHDAY_CARD_PROTO_2_181126.pdf
Schematic
Adobe Portable Document Format - 132.77 kB - 11/21/2019 at 01:11
Preview
BIRTHDAY_CARD_PROTO_2_190313.ods
Bill Of Material
OpenDocument Spreadsheet - 16.93 kB - 11/21/2019 at 01:11
Download
Components
  • 1 × See Attached BOM See Attached BOM
Project Logs
Collapse
  • Interactive Electronic Birthday Card Proto 2 Release
    schwarzrmsu • 11/23/2019 at 14:30 • 0 comments
    Uploaded Interactive Electronic Birthday Card Proto 2 files and updated all relevant material to reflect this latest revision.
View project log
Log In/Sign up to comment
Sign up with Github
OR
Dan Maloney wrote 11/21/2019 at 16:34 • point
I like the approach of suspending the batteries in cutouts to reduce the height of the board. Same with the magnetic reed switch - that's for detecting opening I'd guess?
schwarzrmsu wrote 11/22/2019 at 12:19 • point
Hi Dan,
Yes the reed switch basically is the main power switch for the entire design (The mechanical switch was used for development and is not populated).  Switching off the batteries when the card is closed was definitely one of the trickier parts of the design.  The reed switch is normally open when no magnetic fields are present.
There are actually two magnets in the card, one of the left pamphlet, and one right under the reed switch in the right pamphlet.  When the card is closed, the two magnets actually negate each others magnetic fields out which allows the reed switch to relax and remain open.  When the card is opened, the magnet in the left pamphlet is taken away from the magnet in the right pamphlet, which applies a magnetic field to the reed switch and closes.
I plan on adding more details to this project, as well as upload updated design files as the project progresses.  Currently I have a prototype working, but there are still a few tweaks I wish to make.
Dan Maloney wrote 11/22/2019 at 19:42 • point
Yeah, that is a tricky arrangement for the reed switch. I like the layout of the "candles" too - although it took me a minute to find the MEMS mics. I was looking for cans with tiny holes in them.
schwarzrmsu wrote 11/23/2019 at 14:18 • point
The microphone and LED's were also tricky.  I used LED's that get mounted on the opposite side of the board, and the LED goes through the board to show indication on the opposite side.  This was nice because it kept my card mounting side of the PCB very flat, and it allowed to be use a single stencil for all of my surface mount components.  The microphone had similar constraints.  Likely they have microphones where the port is actually on the bottom (soldered side), and you simply need to provide a drilled hole in the PCB to allow access.  Power management and form factor were definitely the more tricky parts of the project.
UD is open standard that uses SD Card form factor but is not bound to SD card specification.
Project Owner Contributor
UD Universal Digital Card
antti-lukatsAntti Lukats
A card reader that uses black and white squares to identify a card.
Barcode Binary Card Reader
pete-prodoehlPete Prodoehl
The Hackaday card game.
Not A Hack
richard-hogbenRichard Hogben
Business Card
Card001
shahriar-alamShahriar Alam
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Interactive Electronic Birthday Card", please tell us the reason.
Send message
Remove Member
