Winter is in full effect, but we are having some interesting temperature fluctuations this week. This morning it was quite cold at 23F (-5C) outside. Below is the color of the temperature outside:
Later that night the temperature rose to a warmer 47F (8.3C). This is the color of the temperature outside:
This is a great example of how the Weather Color Strip can show you visually the temperature outside without having to look up the weather online. You can simply look at the color that is always there to gauge the temperature outside.
Hope you found this interesting.
schwarzrmsu
