We have been testing the latest build of our RAD2 with a Feather-compatible LoRaWAN board from MCCI (the 4610). This board contains a LoRaWAN radio for streaming data as well as three built-in environmental sensors (temp/humidity, light, and pressure). All functions appear working! To recap that's:
- PIR motion sensing
- RTC set and functioning
- Datalogging to microSD card
- All 3 signal LEDs lighting up
- In addition, because we're using the 4610 we get light, temp, and humidity measurements built in
Here is a ~24 hour sample of temperature data (peaks are me picking up and holding the device):
And some activity data from the PIR (this device was placed on my desk, note when I came in to work at ~9am):
Stay tuned for some longer datastreams!
