We made a quick 3D housing for RAD2. Our primary application is in rodent caging, and we found that they chewed the device up pretty quick when we taped it in the cage without a housing.
So we made a housing, let's see how it holds up!
A project log for RAD2 (Research Activity Detector version 2)
This motion logging Feather-compatible shield contains a PIR motion sensor, real time clock (RTC), microSD card slot, and 3 signal LEDs
