As concluded in the last Chamber Body log (Chamber Body_1), it would be better to have a design that would have its walls and base lock onto each other instead of having a third component locking them together. On that basis, another design was created as shown in the figures bellow.
"Wide Wall"
"Base"
"Long Wall"
The concept of locking the structure is now simpler where:
- Both walls are attached to each other in a similar manor to a jigsaw puzzle
- Both walls are attached to the base by being slotted in their respective positions
- These connections can be supported using glue
Possible concerns:
- Tolerances of manufacturing might affect the assembly of the components
