The new R3.3 Dev Kits as well as USB-C <-> CAN Bus adapters are now available at tinymovr.com.
The new dev kit features a Tinymovr R3.3, a MAD Components 5005 motor, and an aluminum backplate that holds both motor and controller, and is designed to make contact with both controller mosfets and stator for increased cooling efficiency.
The CAN Bus adapter is a revision of the CANable adapter with USB-C connector and DF-13 connectors matching the ones on Tinymovr.
Head over to tinymovr.com to browse more
