I improved the command hunting tool so that you can input HEX Commands on the fly. I plan to make it BLE compatible so that you can send commands from your phone while riding around. Many of the commands I have found do something. for example this command 0xA6 ,0x12 ,0x2 ,0xEF ,0x14 ,0x4E makes the scooter blink the headlight and the mph on the LCD a couple of times but I have no ideas what is doing to the way the scooter actually works. It will require further testing. If anyone wants to hookup a ESP32 and Help out that would be awesome.
