Time passes...
I finished the design of Rev4 (and Rev3 in between). Most important improvement is a 2nd switch to select the current and new switching FETs . The new FETs have a Rds_on of only 9.5 mOhm (at Vsg = 4.5V), which cuts the dissipation almost in half and keeps the board cooler, even with 5 A current draw.
This FET is the AON7407.
And I did a measurement with 24 boards, which showed to real Rds_on to be 7.1mOhm onaverage, because the Vsg is ~15V at the 20V setting. Also the calculated junction temperature is quite low and much more manageable now.
Results (fixed width font anybody?):
Vfet*2 Vload I load P load P fet Tjunc Rds on
73.3 19.55 4.89 95.55 0.358 47.4 0.0075
72.5 19.58 4.90 95.84 0.355 47.2 0.0074
70.2 19.6 4.90 96.04 0.344 46.5 0.0072
69.3 19.6 4.90 96.04 0.340 46.2 0.0071
71.2 19.55 4.89 95.55 0.348 46.7 0.0073
68.6 19.65 4.91 96.53 0.337 46.1 0.0070
71.2 19.59 4.90 95.94 0.349 46.8 0.0073
68.1 19.68 4.92 96.83 0.335 45.9 0.0069
69.7 19.67 4.92 96.73 0.343 46.4 0.0071
68.5 19.67 4.92 96.73 0.337 46.1 0.0070
68.4 19.7 4.93 97.02 0.337 46.1 0.0069
68.7 19.7 4.93 97.02 0.338 46.1 0.0070
72.8 19.69 4.92 96.92 0.358 47.4 0.0074
69.5 19.71 4.93 97.12 0.342 46.4 0.0071
70.6 19.71 4.93 97.12 0.348 46.7 0.0072
68.3 19.72 4.93 97.22 0.337 46.0 0.0069
68.4 19.71 4.93 97.12 0.337 46.1 0.0069
70.7 19.71 4.93 97.12 0.348 46.8 0.0072
71.1 19.7 4.93 97.02 0.350 46.9 0.0072
70.2 19.68 4.92 96.83 0.345 46.6 0.0071
73.5 19.68 4.92 96.83 0.362 47.6 0.0075
70.6 19.7 4.93 97.02 0.348 46.7 0.0072
Average: 0.0071
PS: I just could not bring myself to copy every single cell into the table here.
MagicWolfi
