And then I found an even better FETs that has a Rds_on of only 9.5 mOhm (at Vsg = 10V), which is just as good as the previous one as Vsg >10 V at the output setting of 12V or more.
This FET is the Diodes DMP3013SFV. same 3.3mm x 3.3mm footprint.
And I did a measurement with 19 boards, which showed to real Rds_on to be 7.3 mOhm onaverage, because the Vsg is ~15V at the 20V setting. Also the calculated junction temperature is quite low and much more manageable now.
Results (still fixed width font anybody?):
Vfet*2 Vload I load P load P fet Tjunc Rds on
70.5 19.47 4.87 94.77 0.343 46.4 0.0072
71.04 19.61 4.90 96.14 0.348 46.8 0.0072
70.7 19.62 4.91 96.24 0.347 46.7 0.0072
72.8 19.59 4.90 95.94 0.357 47.3 0.0074
70.6 19.64 4.91 96.43 0.347 46.7 0.0072
72.4 19.64 4.91 96.43 0.355 47.2 0.0074
71 19.66 4.92 96.63 0.349 46.8 0.0072
69.4 19.67 4.92 96.73 0.341 46.3 0.0071
72.8 19.63 4.91 96.33 0.357 47.3 0.0074
73.1 19.62 4.91 96.24 0.359 47.4 0.0075
71.4 19.61 4.90 96.14 0.350 46.9 0.0073
69.9 19.63 4.91 96.33 0.343 46.4 0.0071
72.9 19.64 4.91 96.43 0.358 47.4 0.0074
70.8 19.62 4.91 96.24 0.347 46.7 0.0072
71.3 19.64 4.91 96.43 0.350 46.9 0.0073
73.6 19.6 4.90 96.04 0.361 47.5 0.0075
72.3 19.61 4.90 96.14 0.354 47.2 0.0074
71.9 19.61 4.90 96.14 0.352 47.0 0.0073
74.7 19.64 4.91 96.43 0.367 47.9 0.0076
Average: 0.0073
MagicWolfi
