Building a dirt cheap plywood wall-mounted rack with off-the-shelf 4U rack rails
Thanks for the ideas. I've seen optional rack mount ears for devices that can be rackable/wall-mount/shelved, but the aluminum angle would certainly be a handy/cheap/easy solution!
I built a rack mount for all my stereo gear so I could take it to college with me. None of the components were rack mount, but I found that I could add little pieces of aluminum angle to the sides of each case that would form rack mount ears. Built a case from plywood with matching aluminum rails to mount everything. Came out great, except for the hum induced by the ground loops formed by attaching all the chassis together. Got around that with wood spacers and nylon screws.
Good times.
