I have now finished the code for the long term test. Now I want to know:
- How long will the M5StickC + ENV sensor run with my battery pack?
- Is the MicroPython code correct for a long term use?
- Is the BananaPi + Node-RED good enough for a long term use?
I have done some changes in the Node-RED flow and added the flow to the GitHub repository.
