First I dared to take a look inside the radio. Compared to today's PCBs, it looks pretty wild here ;) Nevertheless, the redirection of the transmitter adjustment is interesting, even if I won't use it in the future ...
I will also no longer want to use the AC power supply in the future. I put the transformer on my side, maybe I need it for future projects ...I will shorten the PCB to get some space. It is planned to use only the on / off switch and the potentiometer to adjust the volume.
