PCBs Populated
A project log for 8-bit Counter
Ever want a display that slowly counts up in binary to 8-bits? Well this project does just that!
sirmylesaverysirmylesavery 12/16/2019 at 15:300 Comments
Around Thanksgiving, 2019, I finally populated the PCBs. Attached some photos of the populated boards, with at least one of them powered.
Some issues I've found: One of the LEDs cathodes was not connected to ground, which is a simple fix. Also add values to silkscreen, to make assembly easier.
