Around Thanksgiving, 2019, I finally populated the PCBs. Attached some photos of the populated boards, with at least one of them powered.
Some issues I've found: One of the LEDs cathodes was not connected to ground, which is a simple fix. Also add values to silkscreen, to make assembly easier.
