Well... that was fairly easy
A project log for Let me control you: Hitachi air conditioner
An attempt to wirelessly control an old Hitachi air conditioner
florianFlorian 06/14/2020 at 03:101 Comment
Yesterday, I hooked up the "central station" and recorded a bunch of data. I tried as many settings as I could, focusing on identifying how commands are sent to the air conditioner and how status are retrieved.
And after just two hours of opening PulseView files, extracting data and compiling everything in Excel here are the result.
      - RAC adapter message: MT P="address" C="checksum"[CR]
      - air conditioner response: OK P="value" C="checksum"[CR]
      - RAC adapter message: ST P="address","value" C="checksum"[CR]
      - air conditioner response: OK[CR]
That's all there is to it! The checksum calculation is straight forward, so I won't go into details here.
For a list of available addresses and possible values, check out the file "Analysis result (2020_06_14).xlsx".
As a confirmation, I connected my FTDI USB to TTL serial adapter directly to the air conditioner, grounded the H-LINK pin and sent a few commands to the air conditioner: everything worked fine.
So the next step will be to learn about Zigbee communication system and explore how I can implement a wireless remote functionality in Home Assistant.
Ken Yap wrote 06/14/2020 at 04:06 point
👍 Well done, persistence pays.
