Here is some images of thermal camera.
a thermal image of a hand:
![](https://cdn.hackaday.io/images/8387111576740814107.png)
a thermal image of a cup filled with warm water:
![](https://cdn.hackaday.io/images/5930881576740844505.png)
a thermal image of a girl:
![](https://cdn.hackaday.io/images/3045251576740889444.png)
a thermal image of a man:
![](https://cdn.hackaday.io/images/1338761576740915640.png)
a thermal image of a running computer screen。
The distance is about 1 meter. At different distances, in order to make the measured temperature accurate, you need to adjust the thermal imaging settings, such as reflectance, etc.
![](https://cdn.hackaday.io/images/6292271576740938491.png)
