Rev A fabricated, loaded, tested. Works as advertised, after I removed a filter capacitor on the analog input which was causing a time constant of ten seconds. D'oh ! May go with a Rev B to correct placement of the filter, make the board larger so the Adalogger can mount on the board ( so many wires ).
Details at:
Mark Omo
Wim Van Gool
J. Ian Lindsay
Abel Rodriguez
