I wanted to try out the zigzag patterns from the last project log. I found a little bug in how a 0 density was treated, but otherwise, drawing this XOR pattern worked out well. Next stop is processing images.
def linesDemo(turtleObj, xlimit, ylimit, steps):
for y in range(0, ylimit, steps):
turtleObj.penup()
turtleObj.setpos(0,y)
turtleObj.pendown()
for x in range(steps, xlimit, steps):
density = (x ^ y) % 8
zigzag(turtleObj, (x,y), steps/2, density)
I ran the program which generated the image above with the following settings: linesDemo(stylus, 300, 300, 10)
