To make my spiral patterns more useful I want to add some contrast element. Seems like drawing a zig-zag pattern is one way to do this as it fills more ink into a given space than merely drawing a straight line.
from turtle import *
stylus = Turtle()
#stylus.setpos(100,100)
def zigzag(turtleObj, endPosition, zigAmplitude, density):
if density > 7:
print("Warning: Density out of bounds, setting to zero")
density = 0
staticAxis = (endPosition[0] - turtleObj.position()[0], endPosition[1] - turtleObj.position()[1])
#Don't zig if somethings wrong with coordiante sets
if (staticAxis[0] == 0 and staticAxis[1] == 0) or (staticAxis[0] != 0 and staticAxis[1] != 0):
print("Error: can't zig unles one and exactly one X/Y coordinate set is the same")
#Just move to the end position and return
turtleObj.setpos(endPosition[0],endPosition[1])
return
if density == 0:
return
if staticAxis[0] == 0:
#We should be moving along the Y axis because start and end X coord is the same
staticStart = turtleObj.position()[1]
peaks = returnZigPoints(staticStart,endPosition[1],density)
amplitudeValues = (endPosition[0] + zigAmplitude, endPosition[0] - zigAmplitude)
for i in range(len(peaks)):
turtleObj.setpos(amplitudeValues[i%2],staticStart+peaks[i])
else:
#We're moving along the X axis
staticStart = turtleObj.position()[0]
peaks = returnZigPoints(staticStart,endPosition[0],density)
amplitudeValues = (endPosition[1] + zigAmplitude, endPosition[1] - zigAmplitude)
turtleObj.setpos(staticStart+peaks[i],amplitudeValues[i%2])
#Send cursor to the final position
turtleObj.setpos(endPosition[0], endPosition[1])
def returnZigPoints(startPoint,endPoint,density):
steps = (endPoint-startPoint)/(density+1) #There is 1 more segment between points than there are total points
pointset = [steps]
for i in range(1,density):
pointset.append(pointset[-1]+steps)
return pointset
Using this code:
stylus.setpos(40,0)
zigzag(stylus,(80,0),40,7)
stylus.setpos(120,0)
zigzag(stylus,(160,0),40,3)
stylus.setpos(200,0)
zigzag(stylus,(240,0),40,1)
stylus.setpos(280,0)
zigzag(stylus,(320,0),40,5)
So if I combine this with a bit of image processing and add it to the spiral patterns I was drawing before, I should be able to make some kind of meaningful abstract representation of 3-bit grayscale. That's next on the challenge list!
Mike Szczys
