First Experience with Linux
I hate ads, I don't want to hate Linux. I thought a reasonable first project would be an adblocker.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
This is a simple DNS adblocker using the Pi-Hole Linux based web server. This setup was designed to be a user-friendly, "plug and play", system that you can plug in and forget about while it does all the heavy lifting.
The hardware in this system is very straightforward:
Raspberry Pi Zero W
A short micro USB cable
iPhone USB wall adapter
32gb micro SD card (overkill but what I got from Microcenter after getting the Pi)
I am very happy with this setup as it is very portable and minimally invasive. As the pictures show below, you can plug this into a wall socket and almost not notice it. I also set up with Raspberry Pi with SSH capability, therefore, I can make changes to it, if needed, anywhere on the network using Putty on windows or SSH in Linux/Mac.
