So this took me a while. The library that I'm using stores the matrix data in a one dimensional array with the length of 40 * 16.
Each LED matrix is 8x8 and are connected in that order:
0 - 1 - 2 - 3 - 4 | 9 - 8 - 7 - 6 - 5
And each LED matrix is wired like this:
0 - 1 - 2 - 3 - 4 - 5 - 6 - 7 8 - 9 - . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 63
When I finally found the error in this function, I had already written a lookup table for all the 640 LEDs. This is fixed for my setup, but it should be possible to rearrange it for others.
int matrix_arrangement[] = { 0,1,2,3,4,9,8,7,6,5 };
void club_matrix_render(void)
for (int i=0; i<led_count; i++)
int led_real_x = i % width; // 0 to 39
int led_real_y = i / width; // 0 to 1
int matrix_number_x = led_real_x / 8; // should be 0 to 4
int matrix_number_y = led_real_y / 8; // should be 0 or 1
int matrix_number = matrix_number_y * 5 + matrix_number_x; // 0 to 9
int matrix_x = led_real_x % 8; // 0 to 7
int matrix_y = led_real_y % 8; // 0 to 7
ledstring.channel[0].leds[matrix_arrangement[matrix_number] * 64 + matrix_y * 8 + matrix_x] = matrix[i];
