Linear Calendar Clock
In this project I use adressable RGB leds to make a linear clock. The clock will be connected to Google Calendar to show my appointments.
If you would be interested to buy a linear clock like this, check out the updated version and more information on my new venture: daylight machines.
All information on the initial build can be found in the project logs or on maakbaas.com.
The GIF animation and display mode images below are from the first version of the design.
Google Calendar Link:
Display modes:
Google Calendar display
Show the time as a rainbow 🌈
Show daylight, night and twilight
Use the display as a goal tracker
Close-up:
  • 1 × ESP8266 development board
  • 1 × 144 LEDs/m addressable RGB LED strip
  • 1 × 3D printed frame parts
  • 1 × Laser cut light guides
  • 1 × Laser cut front panel
  • Redesign and PCB
    Maakbaas • 08/16/2020 at 14:44 • 0 comments
    The linear clock has been on my desk since it has been finished. However, there were a few issues with the design that I wanted to address. First of all, the build quality could have been better, and the build process was quite involved. But more importantly, the display was not very readable in some conditions. In this update I will address these issues and present the second version of the linear clock design.
    Full log (Maakbaas.com)
  • Display modes
    Maakbaas • 01/19/2020 at 12:17 • 0 comments
    For the final log on the clock I will go into more detail on the software side. First I will briefly discuss the software architecture. Then I will explain the different display modes I developed so far. All code can be found on the GitHub repository for this clock.
  • Housing and Assembly
    Maakbaas • 01/12/2020 at 18:50 • 2 comments
    Now that all the physical components are available it is time to finish the housing and assemble the full clock. First I will talk about the housing design, and the process of getting it printed. After that I will show the final product when it is all put together.
  • Let there be light
    Maakbaas • 01/04/2020 at 21:18 • 0 comments
    In this second log I will introduce the electronics used in this project and design the frame to hold the light guides that I designed in the previous log. At the end of this article you will see a first teaser of the fully functional light system for the clock. Let's dive into it!
  • Clock Design
    Maakbaas • 12/25/2019 at 15:17 • 0 comments
    In this first project log I will discuss the design for my clock. The idea for this clock is not to accurately track time to the second, but rather to show the progression of time throughout the day. Furthermore, the clock should be able to display additional information, such as your schedule for the day.
View all 5 project logs
haleyma wrote 07/26/2020 at 12:43 • point
Cool project. Beautiful,clear write up.
Jan wrote 07/26/2020 at 08:02 • point
I read "linear something clock" I click like :)
Awesome design and functionality!
williamrc wrote 02/20/2020 at 00:46 • point
I may have missed it in your logs, but who did you use to do the laser cutting ?
Maakbaas wrote 02/18/2020 at 20:56 • point
Thanks for all the kind comments, I appreciate it a lot!
Woodyw2k wrote 02/15/2020 at 14:31 • point
This is beautiful. I love everything about this from the clean, vintage almost radio-like design to the actual implementation. Really great job!
nexxo00 wrote 02/14/2020 at 11:50 • point
Love the whole 70's sci-fi look. Very 2001: A Space Odyssey.
Daniel wrote 02/14/2020 at 01:17 • point
Love linear time since my pebble may it RIP. Great stuff, and very nice end result!
AviPeltz wrote 01/28/2020 at 18:54 • point
Beautiful!
Grant Giesbrecht wrote 01/20/2020 at 14:58 • point
I really like the look of your project! The laser cut panel looks stellar. Now I want to build one :)
Giulio Pons wrote 01/15/2020 at 09:35 • point
Very nice job!
Maakbaas wrote 01/19/2020 at 13:02 • point
Thanks!
