3D-printable Davinci catapult gift card
the perfect gift to your family and friends and all you need is a 3D-printer (and some wire ;-)
Because a lot of people liked my previous gift card (Fully 3D-printable wind-up car gift card: https://bbprojects.technology/collections/stl-fusion-360-source-files/products/fully-3d-printable-wind-up-car-gift-card-files) and asked if I could create another version of it, I decided to make this Leonardo Davinci inspired catapult gift card. The whole card can be 3D-printed in one go, you don't need any extra parts except for some wire. The card can be printed without support and the print time is about 3 hours with a 0.2mm layer height. The card can be printed using regular PLA. The whole thing is designed to be able to snap fit together so there's no glue necessary. I did a lot of test prints of different parts of the model until I got some consistent and good results. It is of course possible that depending on which printer you use the result may vary.
Because a lot of people liked my previous gift card (Fully 3D-printable wind-up car gift card: https://bbprojects.technology/collections/stl-fusion-360-source-files/products/fully-3d-printable-wind-up-car-gift-card-files )and asked if I could create another version of it, I decided to make this Leonardo Davinci inspired catapult gift card. The whole card can be 3D-printed in one go, you don't need any extra parts except for some wire. The card can be printed without support and the print time is about 3 hours with a 0.2mm layer height. The card can be printed using regular PLA. The whole thing is designed to be able to snap fit together so there's no glue necessary. I did a lot of test prints of different parts of the model until I got some consistent and good results. It is of course possible that depending on which printer you use the result may vary. You can always let me know in the comments which parts work for you and which don't so I can create a second version of the model. I added all the parts separately to for the people who just want to print the catapult and do not have the intend to give the card as a present.
I also created some instructions to add to the experience of building a model kit. The pdf file can be found in the file section.
STL and Fusion 360 source files can be found here: https://bbprojects.technology/collections/stl-fusion-360-source-files/products/3d-printable-davinci-catapult-gift-card-files
Video:
Catapult gift card manual V1.pdf
Adobe Portable Document Format - 697.24 kB - 12/25/2019 at 22:35
Preview
View all 2 project logs
  • 1
    Step by step instructions are provided in pdf format
View all instructions
Brandon Curnutte wrote 01/08/2020 at 17:08 • point
I miss my printer and making cool stuff like this!
Vsevolod wrote 12/27/2019 at 14:27 • point
How do you even print this in 3 hours? My print took 4.5 hours and I cranked up the speed on my printer so much that all corners are blobbed beyond recognition
Brian Brocken wrote 01/03/2020 at 00:09 • point
Hello Vsevolod, I checked again for you and yes the print time with my settings and printer is 3 hours 4 minutes and 31 seconds, but the printer always finishes in under 3 hours. My settings are:
Speeds:
-Print speed: 40mm/s
-Outer perimeter: 30mm/s
-Infill speed: 50mm/s
Layerheight: 0.2mm
infill: 25 percent
Nozzle diameter: 0.4mm
No supports, no rafts, no brims.
Do your settings match my settings above?
Brian Brocken wrote 01/03/2020 at 00:11 • point
And what printer do you have?
Vsevolod wrote 01/09/2020 at 06:09 • point
My Cura settings:
-Wall speed: 60 mm/s
-Infill speed: 120 mm/s
-First layer speed: 20 mm/s
-Slower layers: 2
Infill: 20% gyroid
Layer height: 0.2 mm
Nozzle diameter: 0.4 mm
4 perimeters, 8 skin layers, no supports, brims or rafts
My printer is Ender 3 Pro, upgraded with SKR 1.3 running Marlin 2.0, dual Z axis with belt linkage and piezo Z probe. Since then I have also upgraded print surface to PP sheet and changed firmware to Klipper
Alexander Golikov wrote 04/22/2020 at 07:35 • point
How many Jerks and Accelerations?
And why so many perimeters\skin layers?
PS: stop watching Sorkin
PPS: SKR 1.3 and marlin 2 do not give a guarantee in the growth of endor3 performance
PPPS: Slic3r, 40–60 mm/s — 2.5 hours printing time
