I have used Wireshark in the past to capture wifi traffic between an Android phone and a wifi-enabled toy (a quadcopter) using various methods (e.g. capturing the traffic from an open channel, using a laptop as a gateway between the phone and the toy, etc), however I had no idea how to capture Bluetooth traffic. To my surprise, I found out that Android >4.4 has a feature under the "Developer options" menu entitled "Enable Bluetooth HCI snoop log" that dumps all the traffic to a file. It is worth pointing out that I had to restart the phone in order for Android to start logging the traffic (I suppose this is a trap for young players, I hope this note will be useful to someone) and it was hard to tell if the phone was logging the traffic or not. That's because the location where Android stores the log file is device-dependant and I wasted a lot of time and still couldn't figure out where the file was.
The internet came to the rescue and thanks to this post in Stackoverflow I was able to access the log file from my computer. The "Legacy answer" in the post didn't work for me but I learned about a method to dump a lot of useful information from the phone to my computer and find the Bluetooth log there. This implied connecting my phone to the computer via USB, enabling USB debugging and running the following command:
adb bugreport anewbugreportfolder
By the way, installing "adb" was easier than I though. Apparently, there's a package or a collection of packages in Debian that weight just a few MB and enables you to use this command without installing a huge SDK from Android (hooray!).
The command above generates a zip file that contains a lot of stuff. There's a txt file in the root from which a Bluetooth log can be extracted and turned into something Wireshark can read using a procedure described here. There's a catch though: apparently this log will exist even if the "Enable Bluetooth HCI snoop log" is disabled. However, it won't contain all the traffic, only some low level commands issued by Android to configure and operate its Bluetooth hardware (not 100% sure this makes sense). Once I had the option above enabled and restarted my phone, I found a log file inside the zip that I could read using Wireshark and showed the whole communication log. Success.
In a further update I will describe the first things I learned about the communication protocol.
