Hackaday.io Hackaday.io
Sign up Log in
HighPowerMotorFeatherWing
HighPowerMotorFeatherWing with Infineon IFX007T drivers for two DC motors, up to 40V and 55A, compatible with Adafruit Feather
bernhardbernhard
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
1 followers
  • Description
  • Details
  • Files 2
    • View all
  • Components 1
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
505
0
1
2
Team (1)
  • bernhardbernhard
Join this project's team
  • HighPowerMotorFeatherWing
completed project
hardware
adafruit feather arduino Motor ROBOT
This project is submitted for
  • Take Flight with Feather
This project was created on 12/30/2019 and last updated 6 years ago.
Description
This FeatherWing enables your Adafruit Feather Board to drive two DC Motors. For example to power your robot. It has four Infineon IFX007T driver ICs which give you plenty of power. They support up to 40V and 55A. The whole feather wing is designed to support these voltages and currents. Additionally it has a connector for an emergency stop to safely stop your robot. The feather wing generates 3.3 V to supply other feathers and the input is reverse polarity protected.
The feather wing also features a ADS1015 ADC to measure the current and the back-EMF of each motor. This can be used to implement a speed control of the motors and thus enabling smoother motion of robots.
A demo software is available here: https://github.com/generationmake/HighPowerMotor
This project uses a Adafruit Feather Basic M0 and my HMIFeatherWing:
Files
HighPowerMotorFeatherWing_mounting.pdf
mounting instruction with coordinates of mounting holes for 1.0
Adobe Portable Document Format - 45.46 kB - 01/01/2020 at 22:55
Preview
HighPowerMotorFeatherWing_schematic.pdf
schematic 1.0
Adobe Portable Document Format - 309.79 kB - 12/30/2019 at 01:24
Preview
Components
  • 1 × HMIFeatherWing https://hackaday.io/project/169155-hmifeatherwing
Project Logs
Collapse
  • Mounting instructions
    bernhard • 01/01/2020 at 22:58 • 0 comments
    I just added a pdf files with coordinates and sizes of all mounting holes for 1.0
View project log
Log In/Sign up to comment
Sign up with Github
OR
A versatile ESP32-C3-based control board for combat robots, featuring BLE gamepad support for seamless wireless control.
Project Owner Contributor
ESP32 Combat Robot Controller
schwimmflugelSchwimmflugel
We used lego mindstorms components, and Husarion Robocore board to create self-balancig robot, using Lego gyroscope and MPU accelerometer.
Gyro-bot
czelusniakkrzysztofczelusniak.krzysztof
Using new technology to bring an old 4 axis DC robotic arm back to life
RobotResto: Restoring a 4 Axis Arm
reiner-schmidtreiner schmidt
Semreh is a high-performance line-follower robot developed by Tamandutech, the robotics team of UFABC, built for precision and speed.
Semreh - Advanced Line-Follower Robot
tamandutechTamandutech
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "HighPowerMotorFeatherWing", please tell us the reason.
Send message
Remove Member
