I've now replaced the TFT capacitors on the design with surface-mount equivalents, and tightened up the copper just a wee bit more. Electronically it's the same, of course, but it's a more efficient design.\
(Keeping copper traces as short as possible both saves on copper, and minimizes the electrical resistance between components. The amount of either is tiny and the amount saved is minuscule, but these things do add up.)
bobgreenwade
