Hackaday.io Hackaday.io
Sign up Log in
StepperMotorFeatherWing
StepperMotorFeatherWing with Trinamic TMC5130A-TA drivers for two stepper motors compatible with Adafruit Feather
bernhardbernhard
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
3 followers
  • Description
  • Details
  • Files 2
    • View all
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
624
0
3
1
Team (1)
  • bernhardbernhard
Join this project's team
  • StepperMotorFeatherWing
hardware
completed project
adafruit feather arduino Motor STEPPER trinamic ROBOT
This project is submitted for
  • Take Flight with Feather
This project was created on 12/31/2019 and last updated 7 years ago.
Description
This StepperMotorFeatherWing allows you to drive two stepper motors with your Adafruit feather board. The board is equipped with two Trinamic TMC5130A-TA stepper motor controllers. These controllers steer the movement of stepper motors mostly on their own and require only very small computing power on the feather board. The controllers are connected via SPI.
This feather wing has also special features to support its use in robotics. The input is reverse polarity protected and allows input voltages up to 40 V to have enough power to move big robots. Additionally it has an input for an emergency switch. This switch stops all motion by hardware functions when pressed.
The onboard voltage regulator also powers the feather board.
Files
StepperMotorFeatherWing_mounting.pdf
mounting instruction with coordinates of mounting holes for 1.0
Adobe Portable Document Format - 42.52 kB - 01/01/2020 at 22:54
Preview
StepperMotorFeatherWing_schematic.pdf
schematic 1.0
Adobe Portable Document Format - 379.19 kB - 12/31/2019 at 02:28
Preview
Project Logs
Collapse
  • Mounting instructions
    bernhard • 01/01/2020 at 22:58 • 0 comments
    I just added a pdf files with coordinates and sizes of all mounting holes for 1.0
View project log
Log In/Sign up to comment
Sign up with Github
OR
A modular component system to help with robot building. Because motor drivers are expensive
Project Owner Contributor
The Arducompute
floppidydingoFloppidyDingo
A Complete Step Motor Controller and Driver Board
Single Axis Step Motor Controller/Driver Board
bharbourBharbour
Three axis stepmotor driver, limit switch conditioning and power supplies.
Stepmotor Driver Board for TI Tiva Launchpad
bharbourBharbour
Ultra small Fully autonomy capable UAV autopilot
Lisa/S Autopilot
piotr-esden-tempskiPiotr Esden-Tempski
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "StepperMotorFeatherWing", please tell us the reason.
Send message
Remove Member
