One problem I had was with a single support point, the tubes would swing a bit after the striker hits it. This could cause a double hit or missed hit depending on the swinging and time of next strike.
I decided to drill a 2nd pair of holes and run 2 wires to support the tube. The sound is still as good as before! And now the tubes are much more stable.
