This project is currently shelved while I complete a couple iterations of the "1978 Heathkit Digital D&D Dice Tower" I wish I had as a kid playing AD&D. But, don't fear it will get resurrected in a number of future projects including the Digital D&D Player's Sheet, The Ultimate Hotwheels Timing Computer, and the Heathkit Delux Digital D&D Dice Tower.
Here's a quick description of the project as it exists today.
Hardware: The case was purchased from Amazon.com. It's new but certainly looks period. It was modified to contain the CRT in the top portion of the case for heat dissipation. The front faceplate was cutout for the CRT display and contains the thermal printer and a handful of buttons, a 3-way switch, and the pot for volume control. The rear faceplate has the PS/2 keyboard port, a USB type B female port, and a standard three prong AC power cord jack with integrated power switch. A cheap 12v power supply in an open frame is screwed to the inside of the rear faceplate. This 12v supply drives the CRT, controller board, and serial printer. The USB type B port is a panel mount conncetor that has a small 3 port USB hub connected inside the case. This hub has a cheap USB FTDI RS-232 interface card plugged into one port. The kind of card you can buy off Amazon for $9. It provides a TTL serial interface to the controller board that is used for serial console to the development PC for debugging. An Atmel-ICE is plugged into the other port of the USB hub. It's connected to the AVR processor on the controller board via it's ISP port. A single USB connection provides both ICE and serial console interface to the device. It's a tight fit but it's workable and comes apart for updates relatively easy. I'm impressed everything fit as well as it did.
The CRT is a 1978 Ball TV-50 5" Data Display Monitor. It was pulled from an old CNC machine (I don't know which type) and I bought it on E-bay surprisingly cheap. It's in very good condition with no burn in or any other sign of prior use.
The hand built controller board was built on a Adafruit full-sized protoboard. It sports a ATMEGA1284P processor with 20 mHz crystal, 7805 voltage regulator, connector for PS/2 port on the back of the case, and a plugin daughter card. The daughter card was built on a Adafruit half-sized protoboard and contains the LM386 audio amp and the inverting transistors for the TTL CRT interface. The inverting transistors are required because the data signal to the CRT is driven by USART0 in SPI mode on the microcontroller. When the USART is idle, it drives the output high. This caused a problem with the horizontal refresh creating some ghosting and a vertical bar on the left side of the screen. To fix this, the signal from the SPI is inverted and the character bitmap was inverted as well. The horizontal sync is generated by timer/counter 1 and the vertical sync is generated on a generic output pin. There is no dedicated video controller.
Software: The software is all written in C from scratch using the Atmel Studio 7.0 IDE and associated GNU toolchain. It's architect-ed to create a dedicated application devices. So, it doesn't provide a loader like a user OS. However, it's organized into drivers (CRT, serial, sound, ps/2 keyboard, etc.), services (text windowing manager, UI objects such as text box/radio button/check box/menu, file system, etc.), a simple task/screen manager, and application tasks that are organized into "screens". The user application is written as a series of files that represent each screen of the application. Each file has at least a minimal set of global data structures and a couple function handlers that implement the screen. The data structures describe the UI objects that comprise the screen and the function handlers provide the functionality for these objects. The task/screen manager parses the data structure to dynamically load each screen's data into RAM when that screen has the focus. If a subsequent screen is navigated to, the manager frees the memory for the previous screen and allocates and loads the data memory for the new screen. The application developer does not need to bother with the details memory management at this level and large applications with many screens can be developed and run on a processor with just 16K of RAM. In addition, the task/screen manager implements a very fundamental version of non-preemptive multi-tasking. However this only applies to the services and application level code. The drivers take advantage of the AVR's robust interrupt controller for synchronous and asynchronous tasks. Therefore, the screen continues to display perfectly, sound plays, and the keyboard operates even if the user application spends several seconds in a loop or a complex calculation.
The CRT driver is the root of the application environment. It requires a significant amount of the CPU cycles and it cannot be interrupted during much of that time. If the CRT driver were to be interrupted, the display would visibly glitch. Therefore, most other drivers are not interrupt driven. I say most but not all. For example, the PS/2 keyboard driver is actually interrupt driven. It does this by selectively enabling and disabling interrupts and the PS/2 bus. Also, the sound driver hooks into the CRT vertical refresh cycle to synchronously play 8 kHz sample PCM sound.
While this all sounds a bit complicated, it's pretty simple in application and the software stack hides most of the details. Performance is very impressive. The system is able to seemlessly scroll text across all of (or a portion) of the screen, play 8kHz sampled PCM sound, read keys from the PS/2 keyboard and read/write text from a serial console a 9600 baud without glitching the screen, distorting the sound, or dropping keys/data.
John Anderson
