Effect
https://cdn.hackaday.io/files/1693067243587904/Effekt.mp4
General information
- original circuit by Technoblogy
- added push button to switch between modes (not implemented in program yet)
- uses standard CR2032 3V lithium button cells
Soldering hints
- add a small dab of solder to one of each SMD pads first
- place each SMD component, apply heat with soldering iron to secure component to first solder pad (with the dab)
- solder other side of each SMD component
- solder all other components except the battery holder. With the LEDs it helps to bend the leads to around 45° after inserting to hold them in place:
- cut the IC sockets pins flush to the board
- solder the battery holder
- done!
Programming the Attiny85
- use a proper programmer or an Arduino Uno or Nano to flash the chip
- install the AttinyCore in your Arduino IDE (or not if you use some other (proper) IDE)
- use the following settings:
- select "Burn bootloader" from the Tools menu
- upload the program
- done!
