I am currently a little bit obsessed with making the construction as simple as possible.
I figured to draw up some sketches and plan out how the parts and functions will be like.
![](https://cdn.hackaday.io/images/3914501578960793601.jpg)
This is the sketch for the corner bracket(???) thing at the four corners, used to pin down the extrusion into a frame as well as supporting the GT2 idler wheel or pulley (attached with NEMA 17 steppers).
The drawing quality is obviously not that good, and I forgot to include a hole for the GT2 belt to move through. More on this later.
![](https://cdn.hackaday.io/images/5029491578960957703.jpg)
This is the brainstorming sheet to see how the y-axis (second layer axis? with one rail instead of two) end brackets as well as the effector would look like.
![](https://cdn.hackaday.io/images/8776981578961013924.png)
This is a very bad sketch for the end effector. As you would notice, it's called a pen effector. It's going to hold a pen.
I was inspired by the ODrive demo video drawing the cool pattern, and I think there would be lots of things I could achieve with a pen and paper, especially in school with my math and science teachers.
Some ideas are:
- Drawing mathematical curves (maybe fractals)
- Drawing big graphs, just for fun
- Holding a laser pointer for cool long-exposure shots (long exposure drawings)
